Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › P.U.R.P. Pumped Up Ringmaster – 3PDT grounds input on bypass?
  • #27672
    Hi,
    Normally I’m a big fan of 3PDT boards, but no room in my layout this time. I’m looking at the supplied diagram for the V3 of the PURP. All clear, but one question:
    Does this ground the input on bypass? I don’t see the usual “diagonal” connection that sends input to ground on the switch. Maybe it happens on the main board?
    Thanks,
    John
    #27673
    mybud
    AFAIK no, because the bottom middle switch (S6) is used for the bicolour LED. You could try using a single one connected to S4 and S5 to free up the S6 lug but this wiring system (for grounding the input in bypass) is optional, again to the best of my knowledge.
