The NostalgiTone Spring Reverb effects pedal adds reverberation to your guitar or instrument’s sound by mimicking the echo effect you get in a large, empty room. Instead of using a coiled spring mechanism to create this effect (as in an amplifier}, it uses the BTDR-3H Brick giving your sound more depth and richness. It’s like playing in a spacious hall even if you’re in your bedroom! With 3 straight forward controls you don’t need a operators manual to get the tone you are looking for. It is kind of a one-trick pony, so to speak, but it does that one trick really well. Once again, Barry delivers!
