First off let me say that I am a fuzz guy, and this is a great sounding pedal!! The build doc says to set the bias trimmer anywhere between 4.5v (smooth) and 3.0 volts(gated). I ended up with mine biased at exactly 4.0v. However I find that there are a lot of really good tones in 2.0v to 5.0v range. So I think the next rainy day I may add a external pot for adjusting the bias.
Thanks for looking!
Great work! If you enjoy experimenting with those gated fuzz tones, you might consider adding a small knob to the side wall. Alternatively, you could put the two values you like best on a switch to save even more space.
The Bass control really makes this Fuzz versatile.
Author
