Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Newbie request – Julius Squeezer
- This topic has 8 replies, 4 voices, and was last updated 4 years, 1 month ago by
Billy.
September 1, 2022 at 3:30 am #26078
InactiveHey all,
total newbie here so be gentle.
I’ve build one pedal at a workshop so far and decided to get the Julius kit.
I’m having trouble identifying the components, has anyone got a clear photo of a populated board so I can sort out my parts?Thanks in advance.
Michael
September 1, 2022 at 9:33 am #26081Anonymous
Guesthi, fellow novice here. welcome to your new obsession 🙂 i had no experience with electronics a few years ago. i would suggest finding a multimeter. its relatively easy to learn to read and will identify resistors and non-polarized caps without doubt. this is a must for me as my eyesight isn’t the best. diodes are few enough to id visually, or with careful deduction. with a few exceptions, the remaining parts will usually be clearly marked. get some workbench magnification if you have not already.
when dealing with a specific bill of materials, you might run into different descriptions of the same part. i.e. 100 nF (nanofarad) = 0.1 uF (microfarad). i found this utility to be extremely helpful to decipher farad units – http://www.unit-conversion.info/capacitance.html
i also found this build report, which doesn’t quite get you there. https://www.buildyourownguitar.com.au/forum/showthread.php?t=10364
other than that, dive in, have fun and you might even find your mistakes are happy accidents.
September 1, 2022 at 9:39 am #26082Anonymous
InactiveThank you
September 1, 2022 at 1:32 pm #26083
SteveModeratorIf you are building the GuitarPCB “Julius” there is a link for the directions that contains the BOM (bill of materials) in the “Description” of the board here (https://guitarpcb.com/product/julius-a-historic-tribute-to-the-classic-orange-boost-compression-circuit/)
-=SteveO
September 1, 2022 at 5:51 pm #26094Anonymous
InactiveThanks Steve
September 2, 2022 at 4:24 am #26096Anonymous
InactiveDoing well so far, not, had every labelled ready to go, started to populate the board with a few distractions in the middle, half way through I was missing bits, turns out I used the wrong resistors in a couple of spots. I wrecked the board trying to fix it so I’ve just ordered a new board and replacement parts…
I’m going to have to shut the door and turn off the phone the next time.
September 2, 2022 at 12:31 pm #26102
SteveModeratorSome food for thought…. If you are going to build more than a few pedals might I suggest you purchase a couple of Items that will make de-soldering components much easier.
#1. A good solder pump (sucker) https://www.amazon.com/Solder-Sucker-Desoldering-Removal-Soldering/dp/B08FDY2SGS/ref=sr_1_1_sspa?crid=1Q152DUPPUAUN&keywords=solder+sucker&qid=1662135846&sprefix=solder+sucker%2Caps%2C139&sr=8-1-spons&psc=1&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFPTFZJQjZFM0hDOUomZW5jcnlwdGVkSWQ9QTAyNDY4MTczNUJSQjFOM1hNRlUxJmVuY3J5cHRlZEFkSWQ9QTAwOTgxODEySFk5M09QWE5JM0w4JndpZGdldE5hbWU9c3BfYXRmJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ==
#2. A good brand of solder wick. Helps remove anything the solder sucker misses, https://www.amazon.com/gp/product/B005T8TNCY/ref=ppx_yo_dt_b_asin_image_o08_s00?ie=UTF8&psc=1
With those in your arsenal, along with some patients, your chances of destroying a PCB will be GREATLY reduced.September 2, 2022 at 4:58 pm #26104Anonymous
InactiveI do have a pump but I was unable to get it close enough to work, the wick I have on hand must be so old that it failed to do it’s job, before any of these could work the board looked like a cheese toastie…
September 3, 2022 at 1:59 am #26106
BillyModeratorMichael if you go to the guides page here there’s lots of beginner friendly information
Have a look at the beginners guide to effects pedal components that should give you a good grasp of components used
