There is a trace on the Bottom Layer that makes that connection when the switch is activated.
You can visually confirm the trace by looking at the bottom underside of the PCB.
B1 to C3
Then there is a trace on the top layer which carries it to the OUT pad which you can see on the Top of the PCB.
C3 to OUT
Those are the two traces that make the connection that you made via the wire.
So now I think I see the problem origin.
If C3 (Bottom Left) does not have a filled solder joint, or the pad was lifted then that ruins the connection from C3 to the Out pad.
Since I see some white around that C3 pad it does look like at least a partially lifted pad.
If that is the case simply leave it as it is with the wire. I personally would not mess with it further.
