I started out building for 1590 (Bs and BBs) enclosures but then moved to 125Bs, since they offer a bit more space and generally are more forgiving. I built this MORC awhile back and have wanted to find it a home but it seemed overkill to use a 125B here. So, a slight return to a 1590B, which accommodated all the options, including the release switch (three-way toggle at the bottom). By dint of some careful measuring, I managed to fit all the components into a fairly tight space.
Nice compression TMM. ‘Less is more’ is my mantra with compressors, but this one’s a keeper for its transparency and sustain. I recommend the release switch mod, which adds subtle but audible options (allows more low end through, as I understand it). Thanks for reading, as ever.
