• This topic has 25 replies, 4 voices, and was last updated 6 years ago by Anonymous.
Viewing 9 posts - 18 through 26 (of 26 total)
  • #15532
    Ok I will switch them. Have you ever used the buffer board before like mine earlier in the post?
    #15645
    Ok so some progress has been made but I can’t make this work. I have wired the pedal just as the wiring diagram shows. Buffer board has been put into the fail pile. T wire on board is going to top left and top right lugs on switch. G point is going to input and output on TRS style stereo jacks. Slanted side tab of jack leads to middle left and right outer lugs. I am using a 3207 ic from the shop. I have power and sound in bypass. Upon pressing the 3pdt, sound is faint, buzzy, and not chorus infused. The rotary switch doesn’t do anything. If anybody sees anything, I am all ears.
    #15646
    I would remove the Roto-Tone myself. Put in the proper Capacitor.
    Then check it.
    Still no improvement.. then re-flow every joint again.
    Check it again.
    I would also be verifying all connections are true with a DMM.
    #15806
    Ok so I took your advice @Barry. I have effect when my LED is off and when I depress the 3pdt, the LED goes off and there is a lot of buzz. It gets worse when I touch the bridge of my guitar, so maybe a bad ground? The chorus does sound great though!
