  • #3492
    Hi,
    I bought a Mini Me Chorus board here in 2013, built it around 2015, and while the chorus sounds amazing, it’s gets scratchy/noisy/hissy unless you are playing very quietly.  The moment you get into it a little there’s the scratchiness again.  Just enough to annoy me.
    I don’t think its the pots b/c pot scratchiness usually happens when you turn the pot.  The depth and rate pots don’t make any noise when I turn them.  There’s no noise in bypass mode.  I’m testing on a quiet humbucker pickup.
    I’m using battery power.
    Anyone know where I should I start with troubleshooting?
    thanks,
    Joejoe
    #3494
    • Dial in the trimmer a little more precisely since it is very fine point where it works best.
    • Test only the pedal wired by itself with only two good cables and nothing else hooked up.
    • Reflow your solder joints and all off-board wiring and check all jacks and reflow lugs.
    That is where I would start and the order that I would do it.
    #3495
    Thanks, Barry.
    I took it apart and resoldered a sketchy looking ground, but that didn’t do the trick.
    Then I tweaked the trim pot and that fixed it. 🙂
    Nice, clean, lush chorus!
    thanks again,
    Joejoe
