Hey everyone!
I’m fairly new to pedal building and built a few clones already, but for some reason the Mastodon Fuzz PCB just isn’t working for me. I’ve been using the simple breakout board sold on the site to house the 3PDT with a 4.7k resistor in it for the LED, and tried multiple wiring configs to make sure I didn’t wire anything backwards and I’m still recieving no output when the pedal is engaged, but the LED turns on. I’ve checked for any bridges and couldn’t find anything that would be stopping the signal, but even out of the enclosure with just the PCB and some aligator cables I’m still not getting the effect. I’ve debated on using a WHOLE new 3PDT, but seeing as it isn’t working without it as well, I’m clearly facing a different issue. I’ve dug through the fourms and videos online to try and troubleshoot the issue, and nothing seems to be working. I’ve also checked component orientation to make sure everything is in the right spot, and still everything looks good. I’m not sure what the issue might be so I’m asking you for help!
-Zander
