Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Ludicrous Speed no sound (solved)
- This topic has 5 replies, 3 voices, and was last updated 2 years, 5 months ago by
December 21, 2023 at 3:03 am #30468
GuestHi, I just built this kit, but no guitar signal in bypass mode and when I push the switch I get a big noise that increase with pedal volumen up.
I double checked schematics and reheated solders, tested with another switch, used 3dpt board and with no board, another IC……but no luck.
Please help
Thanks.
I double checked and reheat all soulders, circuit diagram, used
<div id=”gtx-trans” style=”position: absolute; left: 215px; top: 69.4844px;”>
<div class=”gtx-trans-icon”></div>
</div>December 21, 2023 at 3:25 am #30469
BarryKeymasterReverse the 2 blue wires at the OUT Jack.
I think that is it?
Your Main board OUT G pad (blue wire) should go to the Jack Sleeve (Ground) where you currently have the blue (audio wire) connected. So if you just reverse them at the jack you should be fine. I am pretty sure the stereo In jack is wired correctly.
Needs to be like this.
Not all jacks are the same orientation so you just need to recognize the center hole is Sleeve (ground) and the other one is Tip.
December 21, 2023 at 8:37 am #30471Anonymous
GuestThanks for so quick reply, I just reversed output jack wires, but unlucky, now I get no signal at all, no noise, nothing switching either on and off.
Thanks.
December 21, 2023 at 8:46 am #30472Anonymous
GuestVoila !! i got new findings, if i just introduce the tip of the input jacks it works, otherwise not…
Working bypass and effect
when pushed to the end not working
December 21, 2023 at 12:47 pm #30473
PlaysforfunModeratorHey wurly. Let’s get this working. Don’t let these jacks mess you up. Study it so you know what tab goes to which connection. The last pic you posted shows Orange to Sleeve, Blue to Ring and Black to the Tip. Tip is signal. The other two are power (ground). The tip hits the connection with the tallest bump away from the base. The tab is almost always opposite or straight across from the connection point. Sleeve is easy to see because it is right there visibly having a tab to solder to. That is always ground and usually we will pick black for that wire if we have a choice. So what I see is that you you probably want the blue wire from the footswitch to solder to the tip (signal). Since you are incorporating a battery, the black from the battery snap goes to the Ring connection which should be the tab opposite the connection with the short bump. If no battery there would be no need for a ring connection at all. Lastly Ground solders to the Sleeve. Looks like you have that one correct. So Sleeve= obvious, Ring= short bump, and Tip= tall bump. Happy rockin.
December 22, 2023 at 5:04 am #30489Anonymous
GuestThank you Sir, it works now ! great pedal, love it, thinking to build another one.
Happy Christmas
