  • #18031
    The wiring diagram shows lugs 4,5, and 6 on the footswitch (when not using a FS board) going to the LED spot instead of S4, S5, and S6 on the board.  I should  wire it like other GPCB projects I assume?  Thanks.
    #18034
    Sent a message to Barry to address it. They just be moved to the appropriate S4, S5 & S6 holes.  Good catch!
    #18035
    FFS I must be losing my mind. I will fix it directly.
    Yes it would be kind of hard to populate an LED when I have the led holes plugged with the LED footswitch wires.
