  • #3173
    I’ve had a box of shelved pedal projects for years, a graveyard of sorts, where I failed to complete kits sold from other manufacturers. For years I thought I had messed up soldering the PCBs.
    I recently went back at these with a new soldering iron and the GuitarPCB 3PDT Bypass boards. I tore out all the existing wiring and followed this offboard wiring guide. The 3PDT Bypass boards made everything simple.
    I’m happy to say that the graveyard now contains 4 fewer pedals after a marathon Sunday night soldering session! Thanks, guys!
    #3174
    Thank you for the kind report!
    #3180
    Defo the best 3PDT boards out there, placement is perfect and if you use them with gpcb boards even better using another small wire via the S5 pad  to ground it
