Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › I’m MUFF’N defeated
- This topic has 4 replies, 5 voices, and was last updated 4 years ago by
June 3, 2022 at 6:51 pm #24868
I’m trying to build a creamy dreamer version of the MUFF’N with no success. I’ve done the clipping mod and the mid scoop control mod. With an audio probe I have sound all the way to Q4 then nothing. I have power at r22,r25 and to one leg of c13. I’ve reflowed all the joints in these areas and replaced the capacitor at c13. This is a combo build with an emerald ring, I have sound in bypass and the emerald ring also works. I’m reaching out so I don’t have a MUFF’N build of shame. My Q readings are as follows.
Q1 C 6.24 B .53 E 0
Q2 C 8.17 B 1.23 E 0
Q3 C 4.21 B .56 E 0
Q4 C 9.03 B .04 E 0
This was done with the transistors installed and they are 2n5088, also I had 9v at the one leg of c13. Any insight would be greatly appreciated.June 5, 2022 at 12:51 am #24888
BarryKeymasterI would start by doing things like re-flowing all the pads. Then after that try again. It is a bit of a Sherlock mystery sometimes. I would also make sure you have very firm transistor connections. If they are kind of flopping around in there it can cause a problem like this.
You can bend the leads back and forth a few times at opposite angles to get more traction on the transistor.
Verify the pinout of the transistor you are using as well.
June 5, 2022 at 1:01 am #24889
BillyModeratorApart from Q3 your transistor collector voltages look high
What are the voltages on the empty sockets
I can’t see any incorrect values all look good
The only resistor I’m not 100% on is R11 can’t quite make out the multiplier band
June 5, 2022 at 7:50 pm #24902Anonymous
InactiveThis is James again. So I’ve spent a few hours on this MUFF’N this afternoon following the recommendation from Barry and double checking r11 as Billy mentioned. R11 is a 22k and my joints couldn’t be any more shiny, I adjusted my transistor legs and made sure everything was tight. Still nothing, so after a cold PBR I decided to change c13 from a box to a ceramic capacitor and noticed on the component side no solder came through the board on the leg that isn’t getting power. I redid it and still nothing. Should I solder that leg on the component side as well? My Q readings have changed a little bit, they are
open socket
Q1 C 9.08 B 8.67 E 0
Q2 C 8.74 B 1.24 E 0
Q3 C 7.67 B 1.08 E 0
Q4 C 9.10 B .04 E 0
With transistors
Q1 C 9.04 B 8.64 E 0
Q2 C 4.22 B .55 E 0
Q3 C 4.17 B .55 E 0
Q4 C 9.06 B .04 E 0
My win streak has ended in a fiery crash with this one. Barry can you go back to sending me the boards that work on the first try?
October 24, 2022 at 12:23 pm #26562Anonymous
GuestDid you ever get this issue resolved? I just built two Creamy Dreamers with almost the exact same issue. I get sound through my probe up to C12…then nothing.
