  • #24664
    Can someone help me with how to wire my pedal as always on?
    I want to skip the installation of the secondary board and switch and just install jumpers or bus wire on my main board.
    The pedal I am building is a G2 Animal.
    This is my first pedal build, appreciate your support.
    thanks Bob
    #24665
    If it’s a single circuit and not a combo build, you can leave out the stompswitch altogether and wire the jacks directly to main PCB “In” and “Out” points. Be sure to pay attention to the “T” (stands for “Tip”) at the respective “In” and “Out” points on the PCB – they go to the Tip on the jacks. Run the DC jack simply and directly to the positive and negative respective supply inputs on the PCB.
