Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › film box vs ceramic caps.
- This topic has 9 replies, 5 voices, and was last updated 4 years, 4 months ago by
June 28, 2022 at 4:05 pm #25162
GuestIs there a functional difference for pedal purposes?
For instance, when the build doc shows all those boxes, will it make a difference if they’re all ceramic instead?
Or, like my current Vibe project, I lack a 6n8 box capacitor. But I do have some ceramic monolithic ones. Should I be worried about some functional issues, or just toss in some film caps when I order more parts?June 28, 2022 at 6:23 pm #25164
Big OParticipantI think it depends upon the tolerance of the caps. That is +/- percent. If the tolerance is pretty tight – that is 5 percent or less, I don’t think I would be worried about it. But don’t quote me on it.
June 28, 2022 at 7:03 pm #25165
CybercowParticipantMoriearty – most ceramic caps have about a 20% tolerance, whereas most film caps range between 10% and 5%. Other than that, as long as the voltage ratings are sufficient, there is no sonic difference. The only caveat to using ceramic caps is (in my experience) power supplies and timing circuits. Electrolytics are best for power supplies and films are better in timing (clock) circuits.
June 28, 2022 at 7:29 pm #25166Anonymous
GuestGood to know. I’ve been doing a lot of learning, with no real electrical background. Thanks, guys.
So for the Vibe, might be worth sticking with films. Cheap enough and I wouldn’t feel bad having a few left over.
Adding it to my list.June 28, 2022 at 10:07 pm #25169Anonymous
GuestLet’s throw in MLCC, multi-layer ceramic capacitors as well. They are small, reasonable and work well in pedal applications.
July 1, 2022 at 6:34 pm #25205Anonymous
GuestFurther question: On a couple of these boards, there’s a smaller oblong symbol inside the box for capacitors’ footprint.
Is this supposed to specify a certain type, or just a ‘it will fit here if you use a different kind’ type of thing?July 1, 2022 at 8:58 pm #25209Anonymous
GuestI think you are looking at the smaller square boxes that are used for the lower value ceramic caps.
July 1, 2022 at 9:21 pm #25211Anonymous
GuestNo, I double-checked my synapses for crossfires on that one.
Like C4 and C6 on the Add Verb.
Actually intended to note something, or just different labeling? The larger boxes on the D’Lay and MiniMe don’t have that.
July 1, 2022 at 11:24 pm #25213
BarryKeymasterJust there to show you you can also use MLCC or ceramic which will also free up space for top mounted jacks in that particular build.
July 2, 2022 at 6:34 pm #25228Anonymous
GuestSo essentially just a label difference.
Thanks again, guys! -
