Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Disturbance: no bypass or effect
- This topic has 8 replies, 4 voices, and was last updated 5 years, 9 months ago by
February 19, 2021 at 3:17 pm #17239
InactiveI’m stumped. I’ve triple-checked the wiring against the build guide, measured for continuity (all seems to check out), and measured voltages at the DC socket, both ICs (see below for values) and still have zero signal with no bypass. I also checked the input/output jacks and both are wired correctly. Diodes seem to check out as well.
Other issues: The foot switch LED not working, LEDs at D3 and D4/D5 all operate correctly via SW1.
IC1
4.69 9.37
4.69 4.66
4.49 4.69
0 4.68
IC 2
4.69 9.37
4.69 4.68
4.69 4.68
0 4.68
February 19, 2021 at 3:20 pm #17240Anonymous
February 19, 2021 at 4:06 pm #17242
CybercowParticipantWhere are the Green, Black and Red wires on the stompswitch going? (Can’t see where all the wiring goes. The stomps with wiring doesn’t look right with how the LED is applied.)
February 19, 2021 at 4:22 pm #17243Anonymous
InactiveGreen: goes to S6
Black: goes from S5 to center switch lug
Red: From stomp switch to S4
Yellows: from input & output tips to stomp switch and bypass jumper
Blues: Input & Output to PCB
Blacks: Input & Output Sleeve to ground on PCB
February 19, 2021 at 5:24 pm #17245Anonymous
GuestNo bypass indicates incorrect wiring of the jacks to the foot switch. I believe you are using the wrong terminal on those square jacks.
February 19, 2021 at 6:53 pm #17248Anonymous
InactiveI’m on kid duty so I’ll have to wait a bit to open the pedal back up to confirm but this was the diagram I used:
February 19, 2021 at 6:58 pm #17249
BarryKeymasterYah what he is saying is make sure that Tip is actually Tip on the square Jacks. (Your Yellow Wires)
Use your DMM in continuity mode to verify.
Like he said if there is no signal in bypass that pretty much indicates bad jack wiring.
Another possibility could be bad patch cables
February 19, 2021 at 8:41 pm #17252Anonymous
GuestThe last (unlikely) possibility would be a bad a defective foot switch
February 19, 2021 at 9:01 pm #17253Anonymous
GuestThe status LED may have the leads reversed. The Anode connects to the center pad and the cathode connects to the outer pad. The right pad marked with a white box is for the bypass position LED cathode.
