Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › ColorTone Supa Tone Bender Drill Guide
- This topic has 4 replies, 4 voices, and was last updated 1 year, 10 months ago by
Big O.
December 24, 2023 at 12:28 pm #30513
VanWhyParticipantIs there a drill template for the ColorTone Supa Tone Bender v4? I don’t see anything in the build docs. Or maybe there is a similar 3 knob pedal template that can be used? Thanks.
December 24, 2023 at 3:56 pm #30515
BarryKeymaster
I am not sure of the image above will size correctly when downloading. If not the build document has been updated.
Be sure to refresh so as you do not get a cached version.
December 24, 2023 at 4:20 pm #30516
ChuckParticipantI suspect, but do not know for certain, that the pot spacing on the 3 pot Tone Bender is the same as the Aeon Drive, Angry Red Lama v2, Blues Buster v2, and Blues Power v2 that all have drill templates included in their build documents.
What I do when there is no drill guide is to first cover the top of the enclosure with painter’s tape, then mark a center line, place the board on the centerline placing the hole for pin 2 of the middle pot on the line, then use a pencil to mark the pin 2s of the other pots. This gets the pots more or less centered on the box. To get the correct top to bottom orientation you’ll need to decide if you’re going to use top or side jacks. With in/out and power jacks on the side you can put the outer pots as close as you want to the top of the box leaving just enough room to fit the pot condoms. If you’re going to use top mounted in/out and power jacks you’ll need to ensure you leave room so the pots as well as some stuff on the board don’t interfere with the jacks. The typical distance between the ‘fingers’ on a PCB mounted pot and the center of the shaft is about 13/16″. Could be a good idea to drill the middle pot a touch larger for a little wiggle room.
December 25, 2023 at 11:18 am #30518
VanWhyParticipantThanks, Barry! Got the template in the updates doc. This thing sounds great, now I can slap it in an enclosure.
December 27, 2023 at 4:27 pm #30532
Big OParticipantSeeing Chuck’s response up above, it supports the thought I have had about a new thread category – Tips and Tricks. I have a few things I do when building pedals that help me and may help others. There are a lot of experienced builders on this forum who probably have loads of tips. Remember, there is more than one way to skin a cat.
