Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Charge Pump Confusion (answered)
- This topic has 6 replies, 3 voices, and was last updated 7 years, 8 months ago by
February 21, 2019 at 12:24 am #4358
InactiveHi,
I saw this listing on the sponsor’s site:
<h2 class=”single-post-title product_title entry-title”>Charge Pump IC for all Pump’d Up series boards 7660S Brand</h2>
The description stated that it flipped the polarity for those projects that utilize the PNP type transistor. My understanding of a charge pump is that it would, e.g.,allow a 9V potential conveniently power a pedal requiring an 18V potential as the charge pump boosted the potential from 9V to 18V inside the pedal. What’s the scoop on this difference of function?February 21, 2019 at 3:00 am #4362
BillyModeratorA 7660S can be used as a voltage inverter for positive ground circuits meaning you can use a normal +9v adaptor and daisy chain with standard negative ground pedals rather than use an uncommon positive ground adaptor the pumped up series integrates it into the circuit if you look at the power supply section in the schematics
The datasheet contains all the information and circuit examples for it’s uses
February 21, 2019 at 3:23 pm #4374Anonymous
InactiveHi Billy,
Thank you for clearing this up for me.
February 21, 2019 at 6:19 pm #4378Anonymous
GuestThe 7660S charge pump can also be used to double the positive voltage although that function is not used in these circuits. The data sheet shows how to add capacitors to do this.
February 22, 2019 at 6:45 am #4404Anonymous
InactiveHi Wilkie and thank you for pointing out the data sheet as the place where the charge pump function and the capacitor values that are involved in boosting potential are found.
February 22, 2019 at 7:19 am #4406
BillyModeratorThis is an interesting read
https://bogdan.nimblex.net/diy/2016/12/08/testing-charge-pump-ics.html
This guy tests a few different charge pumps but initially it explains briefly how it works with the internal CMOS switching, caps charging and inverting the voltage etc
Datasheets are of course great for any component usually giving circuit examples for what they can be used for but not always giving a clear explanation in laymans terms so I usually google to try to understand better for example I like to know what each pin function is
On the 7660S in particular the LV pin (pin 6) took me a while to figure out, when I used a 7660S to give me -3v for a Selmer Buzztone build in conjunction with a voltage regulator
It ended up oscillating with a loud squeal until I eventually figured out LV must be low voltage as soon as I grounded pin 6 the squeal disappeared of course if I hadn’t skimmed over the datasheet I’d have seen the circuit with LV going to a switch to ground but they are definitely not always 100% obvious or clear
Anyway I often breadboard one or two of the datasheet circuits it does help you to understand it’s functions especially if you do what I do and change external caps etc to see how it’s affected but you can waste a lot of time messing around haha
February 22, 2019 at 10:10 am #4413Anonymous
InactiveBilly, thank you so much for this. This is exactly what I was looking for in terms of guidance.
