Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Apollo Tremolo – no effect
- This topic has 20 replies, 4 voices, and was last updated 7 years, 6 months ago by
May 24, 2019 at 9:07 am #5854
GuestHello,
I’tried to build Apollo Tremolo with care, reading the building document. I’m pretty sure that I’ve made a mistake…
Could you help me to find where? I took pictures and made a short video, as you can see now.
Video: https://youtu.be/-ObGkiml6RY
If you have any good ideas, thank you, I’m trying to find sounds with my jamman and audioprobe…
Cheers
Franck
Ps: I’m new, but i built Swah, Tube Screaming Ultra and love them 🙂
May 24, 2019 at 9:34 am #5856
CybercowParticipantfr4nck – I would venture a guess that there is a wiring issue. Double-check that the HOT signal wires to and from the PCB are connected to the pads directly next to the little “T” that is screen printed on the input and output points on the PCB. I tried to examine the photos provided, but I was unable to make out to what connection points they terminate.
The video “sounds” to me like the PCB is not getting any signal input, but the output ‘sounds’ as tho it is correct because of the noise indicators as you adjust the pots.
May 24, 2019 at 10:52 am #5858
BarryKeymasterAgreed Verify the Wiring and be sure the T pads on in and out match the Wiring Guide. We can’t tell from photos. Finally we cannot guarantee an xvive opto couplet will match the specs of the NSL-32. You would need to compare both datasheets. It would be very important that they match.
May 24, 2019 at 10:58 am #5859Anonymous
GuestCybercow: The video “sounds” to me like the PCB is not getting any signal input, but the output ‘sounds’ as tho it is correct because of the noise indicators as you adjust the pots.
Yes, that’s why I made it 🙂
I’ve been reading the document, “in” and “out” wires seem to be in the right places (or maybe I’m wrong?) as you can see with these pictures.
I made another video with my audioprobe… if you have two minutes to watch it 😛 I did not test condos for now:
https://www.youtube.com/watch?v=pRliPUdJd8o (it sounds clipping but when music plays it was completely clean)
May 24, 2019 at 11:03 am #5861Anonymous
GuestBarry: Finally we cannot guarantee an xvive opto couplet will match the specs of the NSL-32. You would need to compare both datasheets. It would be very important that they match.
This is it: https://www.musikding.de/VTL5C2_1 and there’s no datasheet on xvive’s website…
Even if it was not the good octo couplet? The buffer should play?
May 24, 2019 at 11:25 am #5862
CybercowParticipantfr4nck – based on your probing video, there is NOTHING happening on side A of IC1 (output stage of the circuit), but there is signal passing thru side B of IC1 (first audio stage of the circuit). That suggests either the opamp is bad – OR – something is wrong with one or more components associated with the final output stage of the circuit.
May 24, 2019 at 11:27 am #5863
BarryKeymasterThe T-Pad for the Out appears correct.
If this is a kit from Klaus then he has verified the Xvive.
May 24, 2019 at 12:08 pm #5866Anonymous
GuestBarry: The T-Pad for the Out appears correct.
If this is a kit from Klaus then he has verified the Xvive.This is not a complete kit. I bought pieces separatly because I had one of them.
Klaus use this list: https://www.musikding.de/docs/guitarpcb/apollo_bom_en.pdf and I used Apollo’s doc :-/ maybe Cybercow found another possibility? 😉 (I hope I won’t have to buy another octo haha..)
I’ve found datasheet.. but I don’t know with what I’ve to compare.. https://www.thonk.co.uk/Documents/xvive/Xvive5C2%20Non-RoHs.pdf
Cybercow: based on your probing video, there is NOTHING happening on side A of IC1 (output stage of the circuit), but there is signal passing thru side B of IC1 (first audio stage of the circuit). That suggests either the opamp is bad – OR – something is wrong with one or more components associated with the final output stage of the circuit.
Should I pay more attention to C2 C3 R4 before considerating thate IC1 won’t “Stire it up” ?
I replaced IC1 by another (ne5532P instead of TL072 like I just saw in Klaus’s list) and it’s the same.
May 24, 2019 at 12:28 pm #5869Anonymous
GuestIs Ron and Roff are the only difference or I’m wrong? (I’m new in electronic 🙂 )
source for NSL-32: https://html.alldatasheet.fr/html-pdf/205826/SILONEX/NSL-32/293/1/NSL-32.html
Another really short video to ear what I ear from the output… https://youtu.be/8s8AlI503cw
May 24, 2019 at 12:51 pm #5873
CybercowParticipantfr4nk – it appears the “On” and “Off” resistances are not close to matching.
May 24, 2019 at 12:52 pm #5874Anonymous
GuestAnother really short video to ear what I ear from the output… https://youtu.be/8s8AlI503cw
(as i just edited the last post I add it here 😛 )
May 24, 2019 at 12:53 pm #5875
BarryKeymasterI am placing a photo here of a working build that shows all parts clearly and off-board wiring so you may use it to compare against yours. I do this since you have hands on.
If that does not help we will needs to compare voltages of all IC pins so you will need to post your voltages. I am helping my daughter move today but others are always around to help.
May 24, 2019 at 1:25 pm #5877Anonymous
GuestThank you Barry!
Do you think I should replace the xvive? Because I just received new pcb from you, and I have to buy pieces from musikding for them. Did you see the video?
Thank you too for my bonus 🙂
I have now to build Dr Phype, D’Lay, MoRC and EAT. I hope I’ll be more lucky with components.
May 24, 2019 at 2:03 pm #5878Anonymous
GuestCheck the orientation of the opto-coupler. I think you have it installed backwards. The LED leads need to be facing up on the photo and the + lead must be placed on the pad marked +.
May 24, 2019 at 4:13 pm #5886Anonymous
GuestWilkie1: Check the orientation of the opto-coupler. I think you have it installed backwards. The LED leads need to be facing up on the photo and the + lead must be placed on the pad marked +.
It’s true!! I welded it as it is done with it’s pins spread on one side and tight on the other.
It is now in the right direction, and… No sound effect too. Could it be broken?Maybe I should try another audio tests with my audioprobe.
May 24, 2019 at 4:23 pm #5887Anonymous
GuestMeasure the voltage at the + terminal of the Opto-coupler. In one position of SW2 you should be reading a varying voltage and in the other position you should read a steady voltage (set by the BLEVEL pot). If you have voltages, then probe for a signal at IC1B pin 7 and then at R17 and then at IC1A pin 1. Report your findings.
May 24, 2019 at 6:13 pm #5891Anonymous
GuestOcto-coupler voltage at the + terminal :
- Sw position 1: 3.96 > x <3.97 (no changes even if i turn gain pot)
- Sw position 2: 2.54> x <4.89
probe ic1:
- Oscillation
- Oscillation
- Oscillation
- Oscillation
- no sounds
- Oscillation
- Oscillation
- Oscillation
All oscillations sounds have small differences
Probe ic2:
- no sounds (short click when i plug in)
- seems to have sounds but “bitchushed” only when sample sound’s level is heavier
- music from source
- Oscillation
- no sounds
- no sounds (only a short bump/buzz when I plug in my pin)
- no sounds
- no sounds
probe R17: only a short clic when i plug.
Thank you, for your help, good evening I’ll be back tomorow 🙂
Time to sleep here!
See you
Franck
