Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › apollo trem
- This topic has 12 replies, 3 voices, and was last updated 4 years, 8 months ago by
Cybercow.
February 11, 2022 at 5:22 am #23062
Inactivehello guys, jeremy here, i have questions concerning the apollo build.
i dont want to use the kill switch, should i put jumper on it or leave it like this?
second question is : i will use a daughter board for the main footswitch, so s4 s5 s6 become useless or should i had a jumper to have the led blinking?
February 11, 2022 at 11:20 am #23071Anonymous
Inactivealso the dot should be on the + or the – ? i might have this wrong.
February 11, 2022 at 12:21 pm #23076
BillyModeratorFrom the schematic it looks like you can leave the switch out and of course the BLEVEL trimmer the op amps look powered directly from the power circuit
So I’d leave them out you can always add a jumper if needed I’m not 100% on whether the NSL 32 is powered from there continuity check to make sure
Don’t use a 3PDT board with this build D1 is part of the LFO circuit wire it as shown in the build doc
The dot according to the datasheet is the negative side
February 11, 2022 at 12:34 pm #23077Anonymous
Inactivethanks a lot billy, your help is precious
February 11, 2022 at 1:55 pm #23081Anonymous
Inactivei would like to let my daughter board in place, can i still use d1??i’ll have a status led on the D.B
February 11, 2022 at 3:21 pm #23083
CybercowParticipantmodj – D1 on the main PCBs is Rate Indicator LED. So yes, if you want to have a bypass LED, use the LED placement on the daughterboard.
February 12, 2022 at 2:39 am #23097Anonymous
Inactivethanks cybercow, i still wonder if s4.s5.s6 should have a jumper or not, can you help?
February 12, 2022 at 9:36 am #23105
CybercowParticipantmodj – that all depends on if you want the Rate Indictor LED cooperate independently of, or in concert with the stompswitch.
If you want the Rate Indicator on all the time, Jumper S5 with S4 – OR S6. Again, depending on whether you use a single color or dual-color LED.
If using a dual-colored LED only as D1 on the main PCB, there no need to put an LED on the 3PDT Wiring daughterboard.
What we don’t know is if you are using single colored LEDs or dual colored LEDs or how exactly you want to use the Rate Indicator LED and/or the bypass LED. Please clarify.
February 12, 2022 at 11:43 am #23109Anonymous
Inactivei will use a dual on the main board and a single on the daughter board.i want the db led to indicate wether its engaged or not and the d1 led to show the rate wheter its on or off. thanks cybercow
February 13, 2022 at 11:34 am #23124
CybercowParticipantmodj – if you want the LED on the main board to ALWAYS indicate the rate, then do wire anything to S4, S5 or S6 on the main board to the daughterboard. Instead run a jumper from S4 to S5 on the main board with D1 in place. It will NOT change color if you use a dual-color LED, but it will always blink with the rate.
March 14, 2022 at 6:12 am #23690Anonymous
Inactiveso, i finished the build, but have no sound, the led blink accordingly to the rate and shape, i tried put a jumper on sw2 and i have sound but no tremolo effect, now i dont know what to do my soldering is good the in and out are correctly wired. Can someone help?
March 14, 2022 at 6:23 am #23691Anonymous
Inactiveok problem solved i put a jumper on sw2 on the other side and it works like a charm
March 14, 2022 at 7:17 pm #23696
CybercowParticipantmodj – Glad you solved it. It’s wonder what a difference 11 minutes can make. 😉
