  • #16668
    I built an Ancestral Apparition when they first came out, and used it for a time and then I got an amp that had reverb so I took it off my board. Well I changed amps and this one has no delay so I started using it again but I noticed it is slightly below unity gain. My question is can I change the value of R13 to increase the volume or is there a different resistor that sets the level?
    #16671
    Just as a shot in the dark . . . .  if raising R13 to 250K doesn’t do it, try raising R10 from 10K Ω to 20K Ω.
    #16684
    Thanks, I’ll give it a try.
