Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › American Fuzz Pro – Help with first build diagnostic/troubleshooting?
- This topic has 22 replies, 3 voices, and was last updated 6 years, 6 months ago by
Billy.
May 21, 2020 at 10:39 am #12997
InactiveHi all, after some effort I managed to complete my first build – the american fuzz pro. Unfortunately as is common with beginners upon completion it does not work as intended. While I have sound in bypass, engaging the effect produces no sound whatsoever. I probably should have asked for help sooner, and over the course of re-wiring it’s possible I’ve damaged the 9v in pad (although it still seems to read 9v at the solder point). I tried wiring it both with the traditional DPDT wiring and with the DPDT PCB that came with my kit following the guides on the site – both produced the same result. When I had it wired traditionally with the LED in D1 it did not light when the effect was engaged. I’ve attached a few pictures with the hope that anyone might be able to offer some advice for how I would begin to diagnose the problem. I’ve checked each solder point for continuity and they seem to be okay (albeit ugly). Even though it hasn’t been successful I’ve learned a ton and will continue to keep at it. Any advice or help would be greatly appreciated – thank you so much in advance!
May 21, 2020 at 11:10 am #12998
BillyModeratorWe’d need to see a picture of your 3PDT wiring as it is now so we can trace the wiring
It looks like your main pcb IN and OUT ‘T’ for tip pads go to the 3PDT as they should, the black wires, but we can’t see where, it also looks like your orange ground wires go to the jack grounds
Double check your battery snap ground is in fact soldered to the ring lug on the stereo IN jack and not the tip, put a jack in and follow the connections around like below you could have your ring and tip connections mixed up
Not all jack sockets are laid out the same your tip and ring solder lugs may be different so stick a jack in and check
May 21, 2020 at 11:35 am #12999
CybercowParticipantgabbaghoul – it appears both the “IN” & “OUT” wires on the PCB are reversed. Swap the orange & black wires at PCB “IN” and the PCB “OUT” and you should re rockin’.
May 21, 2020 at 12:10 pm #13000Anonymous
InactiveHey Billy and Cybercow! Thank you both for your replies – here’s a better look at the 3PDT switch – hopefully it’s more visible – just wanted to double check before I try anything (or mess it up furthere :S). You guys rule – thanks so much again.
May 21, 2020 at 1:01 pm #13002Anonymous
InactiveJust a quick follow-up – I’ve double checked the input and output jacks and they’re definitely wired to the correct lugs. Cybercow – It’s very possible I’m overlooking something completely obvious, so apologies for my slow understanding – right now on my PCB I have IN (T) on wired to B1 on the 3PDT PCB and the other IN connected to the sleeve lug of my input jack. OUT (T) is connected to BO on the 3PDT PCB and the other OUT is connected to the sleeve lug on my output jack. Does this sound right?
Again, many thanks for everyone’s kind help and patience.
Best,
G.
May 21, 2020 at 2:55 pm #13003
BillyModeratorG zooming in I could see your main pcb in and outs were correct just couldn’t see where they went to on the 3PDT from what you say that’s correct in T to BI out T to BO other pads to jack grounds
Did you check your IN jack tip wire from the 3PDT goes to the in jack tip solder lug and not the ring
Also need a clearer picture of your DC jack wiring
Make sure you’re putting your in cable to the in jack again very easy to plug your cables into the wrong jacks when you’ve got it upside down etc
May 21, 2020 at 3:28 pm #13004Anonymous
InactiveHey Billy – thanks so much for your reply. I’ve double-checked the jacks and I’m confident I have them connected to the correct lugs – I switched to the two that came with the kit just for familiarity’s sake. Here’s a pic of the input jack:
And here’s a closer (hopefully useful) pic of the rear of the DC jack:
Thanks again so much for your help!
G.
May 21, 2020 at 6:04 pm #13005
BillyModeratorAll your components look to be the correct value and orientation
To double check you are getting power to the main pcb take the voltage on the top end of R3
Also continuity check your T pads from the main pcb to 3PDT pcb BI and BO pads and check continuity on your ground connections to 3PDT and jack ground lugs also check continuity from your I and O to the jack socket tips you don’t have to remove your heat shrink just touch the actual sockets tip and sleeve
Make sure your 3PDT also has continuity from the middle common row 3 lugs to their corresponding 3 top row lugs (effects mode)
If this all checks out post the voltages for Q1 to 3s emitter, base and collector legs
May 22, 2020 at 1:39 pm #13014
CybercowParticipantI brought up the potential of crossed main PCB wires only because black wire is typically used for ‘ground’. I just can’t tell where the black wires on the “T” pads of the main PCB “IN” and “OUT” go.
May 22, 2020 at 2:06 pm #13016Anonymous
InactiveHey guys thanks so much again – I can’t tell you how much I appreciate everyone’s help. Unfortunately over the course of working and re-working this project the pad of 9v in has burnt off (a beginner’s mistake, I know) but now I just cant seem to get a wire to connect – I think it’s possible that this was the main cause of my issues to begin with. Pending any ideas of a work-around I’ll re-order a another PCB and try again (the components should be okay). I’ve learned a whole lot and I think I can get it right if I give it another go.
Again a huge thank you to Billy and Cybercow – this is a great community and I can’t wait to show off the pedal once it’s complete.
Best wishes,G.
May 22, 2020 at 2:08 pm #13017
BillyModeratorG just wire your 9v straight to R3 top end leg the side that doesn’t have continuity with C2
Mark I had the luxury of being on my PC that day so could zoom in and see the wires my immediate thought was the same as yours black = ground but easy to zoom in 10x on your PC not so on my phone
May 22, 2020 at 3:56 pm #13018Anonymous
InactiveOh my god it works! Hahaha! Unbeliveable!
So it must have been the bad connection I made at 9v in – crazy. Billy – thank you so much! I was sure I was out of luck… Can’t thank you enough. I’ll be sure to post it to the completed projects forum once it’s all boxed up. 🙂
Again, many thanks to everyone!
Best,
G.
May 22, 2020 at 5:12 pm #13019Anonymous
InactiveBefore I take on the challenge of drilling my first enclosure – If I may ask one more question? I’ve wired a standard LED to D1 (anode in centre position and cathode in the non-white pad. I’ve also added the R13 3k3 resistor to the CLR space on the 3DPT pcb, but it still doesn’t light when the effect is engaged… Not the end of the world, but Is this the correct configuration? Thanks so much, again!
Best,
G.May 22, 2020 at 6:46 pm #13020
BillyModeratorGreat glad you got it going
The LED must be on the 3PDT pcb so I’m assuming you mean D1 on the 3PDT pcb and not the main pcb
It’s correct your LED anode long leg + goes to the middle and cathode – to non white boxed pad
You can check your LED is ok by using a coin cell battery if you’ve got one just stick it in the middle of the 2 legs
If your CLR and LED are mounted on the 3PDT pcb you can use your meter to check it gets power and ground, check from the 9v pad to the CLR and from the other end of the CLR to the LED anode for voltage and or continuity
If you DC jack power and ground go directly to the 3PDT pcb your faulty 9v pad shouldn’t make a difference
May 22, 2020 at 7:38 pm #13021Anonymous
InactiveThanks Billy – this is how I have it now. I checked the LED with my DMM and it lights on its own. When you say check do you mean for continuity? So sorry for my lack of understanding – I’m still learning the very basics. Thanks so much, again – worst case scenario I can always just proceed without the LED.
May 22, 2020 at 8:49 pm #13022Anonymous
InactiveThere doesn’t seem to be continuity between CLR and the other points, so perhaps the 3k3 resistor was damaged when I removed it from R13. I’ll try to find another one to try in its place. Thanks so much again!
Best,
G.
May 22, 2020 at 10:49 pm #13023
BillyModeratorIt could just be a cold solder joint the resistor should be fine just reflow the CLR solder joints apply your iron for about 5 seconds until you see the solder flow on the topside would be easier
FYI you’d get continuity from the 9v pad to the CLR then the other side of the CLR should have continuity to the LED anode, then ground should have continuity to the LED cathode when it’s in effects mode
If you set your meter to 20V DC the V setting with the dotted and straight line (see below) put your black (COM) probe on any ground point and touch your red probe to the LED anode to see if you get a reading you can do the same for the 9v pad and the CLR
This shows where you should get continuity red 9v and yellow ground in effects mode, just ignore the blue line the best way for you to continuity check is to for example put one probe on the 9v pad and the other on the actual CLR leg rather than the solder joint then from the other side of the CLR leg to the LED anode leg that way you’re checking your wire to the LED is also ok then with it in effects mode touch the actual LED cathode leg and any ground pad or the 3PDT lug with the yellow line
Have a look at the beginners guide to components where it explains how a 3PDT works
