  • #13216
    Hi,
    after searching why my After Blaster isn’t working I finally think I found the problem (with help in Musikding Forum).
    As I can see on the board, the blue marked holes are connected. And it looks like that the red mark is the way from the trim pot to the switch. Yellow goes to the footswitch and from there to the Output.
    Am I right, that the right blue wire should be one pin to the left and the yellow and green wires on the right side should swap places?
    Cheers,
    Henrik
    #13227
    Sorry for the issue.
    The schematic drawing from the build document below is correct…
    however the actual basic “Mod” wiring diagram was drawn in error.
    Here is the updated diagram and you can see how it now matches the schematic above.
    Again sorry for the inconvenience. I have updated the Build Document.
