Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › adverb clipping on transients
- This topic has 9 replies, 4 voices, and was last updated 6 years, 8 months ago by
January 21, 2020 at 1:24 am #9872
Inactivehey guys,
built one of these, nice sounding box… but on real dynamic stuff i’m getting some clipping on attacks which just harshes my buzz.
was thinking maybe a qnd fix may be an antiparallel pair of led’s in the feedback loop of q1 would do the trick most likely, but would it be better to perhaps add a series resistance in the audio path that’s bigger than the 27k resistor spec’d?
i can live with it, but would love to be able to put this issue aside. it is ONLY on sharp fast transients. ne5532 oa. all parts stock values, 5% metal flameproofs, mcc caps blah blah.
other than being a smidge above unity gain when engaged, works great in all other ways.
any ideas?
thanks
PjP
January 21, 2020 at 2:02 pm #9903Anonymous
GuestIf the signal coming in is too hot, you may be getting clipping in the first stage of the reverb block. The first opamp stage has a gain of 7.4. (R3 200K / R2 27K). Try reducing R3 to lower the gain a bit. If that works, you may find that the output level is now below unity.
No problem! You can recover the signal level by increasing the gain on the last opamp stage. It has a gain of only ,84. (R7 6K8 + B10K) / R5 20K. Try increasing R7 first. If that messes up the pot tracking, you could replace the pot with a higher value and adjust R7 to give you correct pot rotation. I hope this helps.
January 24, 2020 at 9:45 pm #10084Anonymous
Inactivethanks ray,
i will give it a shot when i get a chance to monkey with it. been gigging A LOT. crazy times. its definitely overloading… not sure if lowering the gain to the stage will actually fix it, as i tend to run it last in line when i use effects and its gonna be slammed by fuzzes and boosts 😉
but i will definitely give it a shot as per your suggestion… got your email, too, thanks bro… just been too balls to the walls to reply yet.
more soon. thanks for the support 😉
jimi
January 28, 2020 at 12:26 pm #10190Anonymous
Inactiveok, all better. WAY easy fix.
i did end up using anti parallel 3mm red leds in parallel with r3, the gain resistor on the first stage opamp. that helped slightly, but not enough. still, if i really hit that sucker, horrible and serious distortion.
so first thing i did was change the opamp. i had a tl062 in there, and it was kinda noisy as well as distorting. grabbed an op275 outta the bin, first thing i grabbed. that took care of most of the noise.
still distorting harshly on transients. so i did the no brainer move, lifted the input connection on the board, and grafted a B500k trimmer in line with it. pin one went to the ground pad, pin 2 to the in pad, and the original connection from the footswitch to pin 3. now i can turn down the input just enough to reduce the transients and get rid of that nasty distortion… i mean, face it, a 5 volt circuit doesn’t have much of a swing before it hits the rails… reading about 78k between wiper and ground on the trimmer, which is about perfect. i can’t make it distort no matter how hard i whack that sucker now. used the volume control to bring the circuit back up to unity gain, which is roughly 12:00 now instead of off.
sounds silken and pristine now. no noise <the series resistance of the trimmer lowers the noise floor slightly by filtering some highs just slightly> no hiss no more distortion. i took some crappy phone pics, but they’re too lame to post, really.
so anyways, thats my q&d fix for distorting transients in the guitarpcb adverb circuit, should anyone else face the issue.hope it helps. rock on!
PjP
January 28, 2020 at 1:10 pm #10191Anonymous
GuestOK! What ever works for you. The input signal was just too much.
January 28, 2020 at 5:41 pm #10210
CybercowParticipantPinkJimiPhoton – great feedback on the solution! Thanks! I’ll keep it in mind when I get around to building mine.
January 28, 2020 at 7:06 pm #10220Anonymous
Inactiveray,
yeah, seemed easiest.
it couldn’t handle the humbuckers output or my pedalboard, no probs at all now.
its got plenty of makeup gain already, so input attenuation was a no brainerthe opamp was clipping, the brick as well.. two different issues. this took care of both with minimal circuit disturbance. the led limiter is overkill, really, but transparent enough to leave in place.
thanks for the support!
PjPMarch 18, 2020 at 10:08 pm #11704Anonymous
GuestThis post is a life-saver! I have hot humbuckers too and it really wants to ‘rattlesnake’ on that attack sometimes ( it’s a neat effect that could possibly be solved by having a toggle to limit the input ). Will be doing this on mine and will post results in a new post!
Thank you for posting, Jimi – hope you’re doing well!
March 18, 2020 at 10:34 pm #11707Anonymous
Inactiveglad it helps! great to hear from you pat! crazy days we’re all living thru… i am doing well for an old freak, lol, hope you and all who read this are the same… wash your hands!!
hope you always have enough, and a little more.
blessings and much love to all
PjP
March 19, 2020 at 1:58 pm #11722Anonymous
GuestNow you know why so many professional studio grade devices use an INPUT pad to control the level hitting that first stage.
Controlling the input level to effects on a pedal board is a vital issue. It is important to reduce the output level (if necessary) of each effect to prevent overloading the input of the next effect in line. It is true that some will wish to have a higher level leaving the board to intentionally overload the input stage of the amplifier. It is just a matter of knowing when and where to increase levels.
Thanks to Jimi for bringing this subject up for discussion on the forum.
