I’m wiring up an American Fuzz > PUTB > 4-Track > PURP > Aeon Drive in series. Won’t be wiring the LED on the 3PDT Wiring Board … do I need a jumper and/or the CLR?
Nice project. The led and clr possibility is there if you need it. If you don’t you can ignore it. Which could also mean that you don’t need power or ground either unless passing them through to another board. Or maybe using one for a star ground or 9v distribution. So the 3PDT board (best in the industry) is a switch board PLUS all those other things. Happy building.
