Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Voodoo Redux Artwork File and Drill Service files.
  • #33900
    Chester Hewitt
    I read through the instructions and I have searched through the site for a High Resolution version of the Face Artwork for the Voodoo Redux Triple Nostalgia Box.  In the drawing I have the input \ Output  and Power jack are not labeled.  They exist on the drill document but not the face.  Before I submit this to Tayda I wanted to check if this was intended or the version I needed?
    #33901
    This is the link provided:
    https://guitarpcb.com/wp-content/uploads/2024/02/GuitarPCB-Voodoo-Redux-Final-art.pdf
    If you have design software, you’re welcome to add any additional labels as needed. Otherwise, this artwork is provided as a helpful starting point, or you can use it as is if you’re unsure how to make modifications.
