  • #36290
    I should have thought about this a little more.. But now that its 90% done, I realized some of my Caps are only rated at 16v. I’ve done a couple vibe style builds and normally in the build doc is says “hey, dumbass! no caps under 25V”. I didn’t see that for this build. Does that mean I am okay with the caps I installed? or am I SOL?
    Thank you!
    #36292
    You’re not out of luck at all! Using 16V capacitors is perfectly fine for most pedal builds — especially since nearly all guitar pedals, including all of ours, are designed to run on 9V power.
    The only time 16V caps would be a concern is if you were planning to run the pedal at 18V, which some builders do to increase headroom. But if you’re sticking with the standard 9V supply, those 16V caps will work just as intended.
    #36724
    Thank you so much Barry for getting back to me! Yes i’m using the 9v power supply so I will leave them(16v)in.
    I got the enclosure in today and was hoping to get this thing working, and of course I ran into a speed bump. It appears I didn’t have any MPSA18s in my parts bins. How critical is it to use that transistor @ q5-q6? I have a bunch of 2n5088s and s9014. I saw these might be okay to use based on https://guitarpcb.com/product/mpsa18/
    is this correct? if so do i need to look for a certain HFe?
    Thanks!
    #36726
    The 2N5089 is likely a closer match, as it offers a higher gain similar to the MPSA18.
    The ones I sell typically test around 800 hFE.
    If you can find a pair in that similar range, feel free to socket and experiment with them.
