  • #28813
    Hi guys,
    I just built the Stones Drive 69 and my Volume is low on it.  I be biased the J113.  Is this pedal a low volume pedal that requires cranking of the amp.
    Thank you
    #28815
    Clear, well-lit photos will be helpful as well as voltage at 9v point and bias voltage.
    Any substitutions should be listed if any.
    #28823
    Thanks Barry,
    The transistors all measure good.  I reflowed the solder and now it is working fine.  I should have known to reflow the solder.
    Real interesting pedal, it really does sound like them.  Nice job Barry!!  I find all your boards to be the best on the internet.  And you have the best prices.
    I appreciate the support!????
