Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › Utilities build
Tagged: Buffers, LoopSwitcher, Paralellizer, Utilities
- This topic has 12 replies, 3 voices, and was last updated 3 years, 5 months ago by
March 12, 2023 at 6:40 pm #27943
GuestI’m interested in a utilities build, largely using PCBs from the mods section. I’m trying to decide if I should make it a single unit or block it off into three or four different units.
I want to have the following:
0.5. Tuner out with accompanying mute switch
1. A pair of loops with order switching for dirt pedals
2. 3 loops I can run in parallel, blend with the dry signal, and mix
3. Three outputs, ABC style so I can use one, two, or all three in any combination. One needs to be balanced with ground lift (DI box), the other two need to be standard Amp out
I’ll likely stick a buffer at each end just for clarity.
I just can’t decide if this is better as a single unit with five loops, a tuner out, two amp outs, and a DI, or break it up into three units.
Any suggestions?
March 12, 2023 at 8:08 pm #27945Anonymous
GuestHmmm… This looks like you will need:
1 Silent tuner board, 1 Order Switching board, 2 Buff N Blend, 3 Paramix ( you can use the outputs of these and/or switch/mix together for outputs).
GPCB doesn’t have a balanced output board. I have a schematic for one if you want to build your own. I can also build one on a VERO board if you wish.
You shouldn’t need any additional buffer boards for outputs as all of the above have buffered outputs built in.
Overall, I always believe in max versatility. If you are going to the trouble to build this, you may as well add all you can.
March 12, 2023 at 8:52 pm #27946Anonymous
GuestI had a couple of buff and blend in my original guess at what I needed. I thought the Paramix controls would make it redundant. If you have the time would you mind educating me on why both are important?
I found this Active DI board over on general guitar gadgets and was thinking of using it, feedback is appreciated.
https://store.generalguitargadgets.com/collections/pcbs/products/direct-box-active-rts-pcbI’m going to think on this, b/c I also recognize what I’m after is kind of an EQD Swiss Thing on steroids.
As for form factor I’m kind of torn between a standard looper (long, narrow, linear layout) and taking advantage of some of the more rectangular enclosures to allow for easier connectivity to rows of pedals.
I enjoy the design phase
March 12, 2023 at 10:44 pm #27947Anonymous
GuestThe Buff N Blend has one balance pot to adjust the mix of the wet and dry signals. If the wet signal from the effects loop is inverted, it may cause a phase cancellation with the dry signal.
The Paramix has separate wet and dry vol pots as well as a gain pot and a phase switch. Therefore it has more versatility.
I suppose you may use all of one or the other if you do not anticipate any phase, gain or level issues.
March 13, 2023 at 1:02 am #27949Anonymous
GuestThen it makes sense to have the extra controls, thank you for the heads up!
March 14, 2023 at 12:55 pm #27961Anonymous
Guest@wilkie1, (out any one else who knows) after looking at how versatile the Paramix is, I have a couple of questions.
1. I’m interested in having three parallel loops all of which can be mixed back into the dry signal. Is three Paramix boards the best way to do this or is it possible with two Paramix and a Buff and Blend? Both space and signal quality are part of my decision process.
2. I’m a bit of a freak for expression pedal jacks. Control the rate and/or intensity on a Univibe with an expression pedal? Yes please. Octave Fuzz, delay, reverb, pitch shifters, EQ, literally anything, I can tweak wile I play.So the thought is a single expression pedal in connected to a row of buffered expression out jacks, all TRS, which given I’m already struggling to fit everything into a Hammond 1590DD (7.4”x4.7”x1.3”) and seriously considering going to a 1550G(8.74”x5.75”x2.01”) just to preserve my sanity. The 1590DE(7.88”x4.73”x2.37”) may be a better option. I’ve also considered staying with the 1590DD and opening the front 3.68” of the top of the enclosure and braising a 1590BB on to of it, giving a two level box with switches raised and pots on the lower deck.
The 1550G will ultimately be the lowest profile of everything but the 1590DD with no modification, but it’s a quarter inch wider than the space I have for this thing, which to be fair isn’t much.
Finally completely different direction, just find/fabricate a chassis that allows me plenty of room for all of this and more and just mount my pedal board on top of it
Did I mention I love the design phase?
March 14, 2023 at 1:40 pm #27962Anonymous
Guest- Yes, you can use 2 Paramix and one BuffNBlend to create 3 parallel effects loops.
- One expressions pedal could be switched between multiple effects using foot switches.
- Stacking enclosures works quite well as shown here:
March 14, 2023 at 4:47 pm #27964Anonymous
Guesti love your idea. i sat on the paramix board for about a year until i finally decided on this monster. if it doesn’t need to be a pedal, you can mash in a few more knobs and switches. this was a 1590D enclosure, so almost too tall for a stomp box, but plenty of room to cram. i have other ideas for a more compact paramix utility box and will probably take another stab at it. inspired by your post 🙂
March 14, 2023 at 4:55 pm #27965Anonymous
GuestThat is a gorgeous build, and something I aspire to. I may be too much of a pedal tweaker to ever commit to wiring that many into a single enclosure, but we’ll see
Now to figure out the Buff & Blend/Paramix/Paramix wiring and how that all fits together and does it’s job.
The thing I’m worried about is that based on the build doc, two Paramix together seem to provide two independent channels and one that is either all dry or modified dry, but not both. I’m hoping the Buff & Blend gives me a fully dry signal to play with and keeps the primary II/IO loop free of dry signal.
They told me I was actually going to need to learn to read schematics, and they were not wrong. I think I’m going to go print them out for both boards
March 14, 2023 at 5:25 pm #27966Anonymous
GuestIf I’m reading this right, the Buff&Blend can pass the full dry signal, whether the Paramix is engaged or not, so the three loops of the two Paramix boards chained together with the Send/Return connections of the first to the In/Out of the second creates the following:
1. Dry signal from the Buff & Blend
2. An II/IO channel that carries the Dry with whatever effect(s) it has.
3. The II/IO channel of the second Paramix which carries no dry signal
4. The Send/Return from the second Paramix which Carrie’s no dry signal.I recognize this is a subject I am largely ignorant of, but am I close?
March 14, 2023 at 6:23 pm #27967Anonymous
GuestLayout, to scare of the boards I think I’ll need for this build.
March 27, 2023 at 2:14 pm #28094Anonymous
GuestStill chewing on this one, and have some questions if anyone has answers. I really appreciate the time, b/c I suspect I need a lot more hand holding and clarification than your average forum member.
1. I look at this and wonder if I stick a Buff n Blend in front if that will keep the IO/II loop as 100% wet, or will it still have the dry signal even if I turn the blend all the way down on the BnB?2. I would assume from the documentation the IO/II loop on the second Paramix would carry some signal from the first Paramix, but b/c it’s coming from the Send/Return loop on he first Paramix I think that means it’s 100% wet?
3. I’m assuming the Wet/Dry control allows true mixing of all three signal paths in parallel with this configuration. Right? or am I an idiot?
Now, this is the entirety of the Signal Chain for the build I’m planning. Assume I’m using breakout boards for switch wiring. I’m trying to put it all in a 1590DD or if I’m being dumb about space, a 1590D
Things that concern me.
1. 13 foot switches among various boards and loops2. 16 pots among various boards
3. 18 TS/TRS jacks around the perimeter, potentially I could put a few on top, but have you seen the number of foot switches and pots I’m planning for? Might be more than this is I can figure out how to feed everything back into five jacks (Guitar In, FX Loop send, FX Loop Return, Amp Out, Mixer/Amp2 Out) something in me wants to be able to push stereo all the way through, but the only marginally more sane part of me says slow down, this is already going to be like eating an elephant
My current plan is to get a powder coated enclosure and use a laser cutter at my local maker space to link foot switches to pots with boxes and carve labels for everything with the laser. I’ve been experimenting and have the required settings and passes for powder coat cutting on lock down. I’ll post the enclosure for the Industrial Fuzz board I’m planning Wednesday or Thursday after I cut it.
I can also make labels with 0.06” thick anodized aluminum, etched by the same laser. I’ll try to make one or two of those at the same time.
what follows is a screen shot of the current signal chain I am contemplating. Comments and WTF are you thinking?! Are welcome and encouraged. Might have made a change or two while writing this huge wall of text that aren’t reflected in this list.
March 28, 2023 at 6:48 pm #28115Anonymous
GuestAfter looking over your posts, I really can’t comment much without knowing what effects pedals you intent to use in each loop and position.
The only thought I have is regarding to EQ. If you use EQ early in the signal chain, it will have an affect on each of the subsequent effects. If you use it last in the chain, it will only change the final tone. You really must try different effects in different positions in the signal chain and listen to the final sound you hear.
