Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › The Vibe Not Working (solved)
- This topic has 12 replies, 4 voices, and was last updated 4 years, 6 months ago by
June 14, 2021 at 2:46 pm #19244
InactiveI built this a couple of years ago and was working perfectly until a couple of days ago. I get a slight gain boost but no vibrato sound. I built this with the Speed Shift mod and the 45/90 mod. Tried turning the trim pot with no luck. I did record the values on the transistors and ICs and will recheck to see if anything is off. Any suggestions?
June 14, 2021 at 6:25 pm #19246Anonymous
GuestAre the transistors socketed. Make sure they haven’t come loose (wiggle test while on). Was there a power surge to the pedal?
June 14, 2021 at 6:44 pm #19248Anonymous
InactiveSockets are soldered to the board and not loose. No power surge to the pedal either. Checked all of the voltages and they read the same as when it was working properly.
June 14, 2021 at 10:42 pm #19251
BarryKeymasterHi, he meant to make sure the transistors in the sockets are not loose.
My best advise is to re-flow the entire board and all off-board wiring since that is the most likely cause.
Standard Operating Procedure for such an event.
June 15, 2021 at 6:21 pm #19278Anonymous
InactiveThanks Barry. I did socket the 3 ICs when I first built it back in May 2017. I replaced the TL074 IC2 with no luck. I refloated everything and it is still not working. Don’t have any spare TL071 or TL061s to see if that it the problem. Even though the voltages on the 4 trannies seems correct, is it possible one or more of these could have failed?
June 15, 2021 at 8:14 pm #19281
BarryKeymasterIt is possible. Perhaps someone plugged it in once with the wrong power supply for one example.
June 16, 2021 at 1:37 pm #19299Anonymous
InactiveWhat is the best way to test the trannies? I have a multimeter that tests for Hfe values.
June 16, 2021 at 2:20 pm #19300Anonymous
InactiveJust realized that these are FETs.
June 16, 2021 at 3:08 pm #19303Anonymous
InactiveLooks like I am going to have to remove the trannies and install sockets. I have 7 2N5457 which are supposed to be similar to the 2N5952. Have no way to match them so I will try various combinations to see what I get. I also found a TL071 which I will swap out.
June 18, 2021 at 1:49 pm #19333Anonymous
InactiveLooks like it was one of the 2N5952s. Put 4 2N5457s (had to reverse the orientation since the pinouts are different) and got a fairly decent vibe sound. Will have to order another matched set of the 2N5457s when they are back in stock.
April 29, 2022 at 4:40 pm #24330Anonymous
InactiveHi,
seems that I have the same issue of Dan.
I just populated the board, double checked all the components but when I turn it on I get only a volume boost and no vibrato at all.
It’s my first build for this specific type of effect and I don’t know what can be the standard voltage values.
Can anyone help me?
April 29, 2022 at 4:49 pm #24331
BarryKeymaster@ Gio – You should start your own thread.
Just because it is not working does not mean it is the same problem.
Dan sorted his out by getting a proper set of matched transistors.
We need more information like where did you get your transistors, which ones are you using and what are the voltages.
April 29, 2022 at 5:57 pm #24334Anonymous
InactiveSorry, I’ll start a new thread. ✌
