I am glad you got it working.
I notice that the wiring diagram doesn’t show the extra mandatory ground wire and I think it should. I will fix that. There are notes in the build doc pointing to using both ground pads on the Vibe.
Right below the main schematic image on page 2 is this:
Build Notes: *There are (two ground pads), G & GND.Both ground pads must be wired to ground for the circuit to function. Connect both directly to the power supply ground for optimal noise free performance.
Anyway I wanted to mention that so other folks did not think the ground pad was literally missing.
