Hello everyone,
I purchased and build the tap tempo add on for pt2399, and run into a very strange “glitch”… The tempo led, gets out of sync every now and while, and then syncs again. I used a metronome to check it, set the delay speed by either the switch or the potentiometer, set the metronome at the same tempo. So for the first 4-6 counts led flashes along with the metronome. Then for 3-4 counts the led flashes out of sync and then again goes along with the beep. I tried all that in various speeds (60bpm ~130bpm, less or more I cant keep along with the tempo 🙂 ). While the actual delay sounds keeps in place, while always seems to be a little faster from the blinking led. Tried different led, same result. Tried the Tempo Double Time input to ground, again it does the same thing… And it’s driving a little crazy as I see videos on the web, with led’s blinking in tempo and mine is acting like it smoked something funny! Could it be a bad taptation IC? Thanks in advance to anyone that will provide any help or thoughts!!!
