Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › SWAH V5 Bias working – no effect (solved)
  • #29636
    Hi everyone,
    i just finished my first guitar pcb build and only bias is working probably, but no effect.
    Otherwise i have done maybe 10 Musikding-builds, so i am just at the beginning.
    I searched the forum for similar topics, but found nothing, that helps me with the problem
    The 14 pin socket was missing one pin, which i fixed with a wire, which should work probably,
    but if you think that could be the problem, let me know. I highlited the Pin that was broken in the image.
    Also i am not sure about the direction of Diode D3.
    Hope someone can help, because the Bias sounds promissing.
    Best regards
    Sven
    #29646
    D3 you are using a Russian diode so it is in backwards. All Russian germanium diodes are opposite orientation.
    #29649
    Hi Barry, thanks a lot. Works perfect now.
    it is so easy, if you know what to do ????
    Best regards
    Sven
