  • This topic has 23 replies, 3 voices, and was last updated 5 years ago by Anonymous.
Viewing 7 posts - 18 through 24 (of 24 total)
  • #19653
    R26 had a MARGINABLY questionable solder joint so i reflowed that. still no decay.
    #19654
    Great.  A function Generator will not work because it is a continuous signal.
    If you have a good signal at IC1-pin16, then look for that signal at IC1-pin1, then IC1-pin8. Double check the values of R11 and R12.  They must be 330 OHM, not 330 K.
    #19655
    i may have checked the wrong pin before because now IC1 pin 16 i get nothing.
    pin1 nothing
    3 very very quiet
    wah sounds pins 5, 7, 8, 9, 10, 12
    very quiet 13, 14
    pin 14 is dry signal
    pin 16 nothing
    #19657
    If you have wah signal at IC1-pin 8, then you have gone through the majority of the circuit. Only C6 and R15 are left before the OUT jack.  All I have done is lead you through the schematic signal path.  Trace signal through those last items.
    #19661
    Are you sure you are not expecting too much out of the Decay setting?
    Check out this demo of a commercial version.
    I have the video set for the Decay section. There is no tonal change just timing.
    You may need to up a video to show us beyond that.
    #19672
    yeah Barry I guess I was. I followed along with the video and, with the right settings, I was able to hear a difference with the decay. I think it was sensitivity down and bias down to get the decay to be noticeable. anyway, I’m really happy with it. I think it sounds great.
    and much thanks to you wilkie1 for being so helpful and patient.
    #19674
    Here to help.
