Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › Super Drive 70’s tone
- This topic has 7 replies, 2 voices, and was last updated 6 years, 5 months ago by
May 19, 2020 at 8:57 pm #12984
GuestDoes anyone think the Super Drive 70’s board could benefit from replacing the tone knobs with ToneTwEQ boards? Maybe one for the fuzz stage and one for the drive stage or one at the end after the Stage 3 boost or at the beginning before the drive? And if so how what would I need to watch out for and how would it complicate things? I’m also considering adding a MiniMe chorus to the pedal. I haven’t planned it out yet so I’m not even sure it would all fit, but I just wanted to ask.
Thanks!
May 20, 2020 at 12:34 pm #12987Anonymous
GuestYou can certainly add a ToneTwEQ to the end of the first stage or the second stage if you wish. The Super 70’s is such a versatile circuit that I would also add an ORDER SWITCHING board to reverse the order of the first two stages. Then I would add the Tone TwEQ before the last stage. This way you can have the Drive push the Fuzz or the Fuzz push the Drive.
Choose you own solution. They will both work.
May 20, 2020 at 3:21 pm #12989Anonymous
GuestAnother option would be to use a 4PDT switch to insert the TonetwEQ between the first and second stages OR between the second and third.
May 20, 2020 at 7:31 pm #12991Anonymous
GuestGreat ideas Wilkie1. Thank you. I like the idea of adding the order switcher, then the ToneTwEQ after stage two. But what about the MiniMe? Would you put that between the ToneTwEQ and stage three or after the Super Drive 70’s?
May 20, 2020 at 8:11 pm #12992Anonymous
GuestIn general, modulation devices are normally placed after distortion and overdrive effects. EQ is usually placed after all effects unless you wish to add EQ to a particular device upstream. The last stage of the Super 70’s is the same as a STAGE 3 Boost. It is a very transparent boost that provides a nice low impedance signal to amps through long cable runs. We usually leave that ’til last.
May 20, 2020 at 8:50 pm #12993Anonymous
GuestExcellent advise! Than it shall be stages 1 & 2, then the chorus, the ToneTwEQ and finally the boost. Thank you so much. That’s really helpful!
May 20, 2020 at 9:49 pm #12994Anonymous
GuestDon’t forget the Easy Order Switcher! 🙂
May 20, 2020 at 11:02 pm #12995Anonymous
GuestOops. You’re right. I forgot to list that between stages 1 and 2. It will definitely be there. It’s going to be a very cool pedal!!
