Hey there everybody. I’ve just “completed” my super 70s build but it isn’t working. Based on my audio probe I have signal to the IC pin 3 but nothing out. I’ve tried switching the IC but it doesn’t seem to be the problem as both IC’s get signal to pin 3 and then it disappears. Thanks in advance.
I figured it out Billy, thanks for the response. I had no voltage to the board. It was strange though I used the lower of the two 9v pads on the board and even though it showed continuity with the upper 9v pad it wouldn’t power the board. Pulled the wire and moved it to the upper pad and it rips now.
Author
