  • #28236
    Hello,
    recently i’ve found an old Sunn-T pedal which i’ve build several years ago. after some research i realized that it is most likely a V1 pcb. now that i’ve seen hat V3 is the current one: what is the difference between all the Sunn-T pcb versions, especially v1 vs v3? Regarding parts list, they look pretty much the same. would you advise someone to also build a V3 if that person already has a working V1?
    thx in advance,
    Tschem
    #28239
    Page one of the new build document lists the only differences:
    It was redesigned to use on-board pots and incorporate a better circuit protection diode.
    If you have a working one and do not need a 2nd working one there is no reason to.
    Thats it.
    #28243
    Oh nice. Thx a lot!
