Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Sriracha Hot Fuzz – led not engaging (solved)
  • #22438
    Hello all,
    Can anyone see any issues with this? I had a few resistors that I did not have the value for, but I soldered 2 together to make the value and tested them after on a multifunction tester to ensure correct resistance.
    I’m getting no LED light, everything else works as normal. Any advice would be really appreciated.
    #22442
    You do not have a current limiting resistor CLR in the 3PDT wiring board which is the board you are trying to run the LED from. You must use a resistor value of 1k8 to 4k7. The only reason to put a CLR resistor in the main board is if you are running the LED from that board.
    That should probably do it.
    #22462
    Sometimes it’s the simplest things that I have completely overlooked!! That solved it and it works perfectly now. Thank you so much!!
