Hey all. New guy here. I just built a sho nuff v3 today. I had to remove a wire (s6) from the stomp switch to get the device to operate. Not sure why but I assume the wire is unnecessary? Any help?? Also, the 100 k crackle pot has zero range. Absolutely no signal till the end of the sweep, then it’s 100% on. Sounds killer, but I know this isn’t right. I am guessing I need to eliminate a wire there as well. Any help??
thanks In Advance
zedd
