Viewing 1 post (of 1 total)
  • #28606
    After a lot of thinking and planning, I’m going to try a BERatt, TSUltra, tone tweak combo.
    my goal is to be running the BERv4 and TSU in parallel, which I’m trying to do by running the TSU into a buff and blend and putting the BERv4 into the “loop” of the BnB. I think I’ll be able to select  each separately, and connect the Tone TwEQ and the TSU with a 4PDT order stitcher so the Tone TwEQ will either be at the beginning or the end of the chain.
    My goal is a signal chain like this:
    Input ~> ToneTwEQ ~> TSU ~> BnB ~> BERv4 ~> Output
    With a 4PDT order switcher between the TSU and the TT
    I’ll attach a picture of my intended routing, can anyone help me figure out if it’s a mess? Based on how I have this set up the Order switcher is connected to he input and output. If I’m wrong about the order or just plain wrong, please let me know.
    PS, as soon as I posted this I realized due to the design of the BnB I may need to have the TSU and the BERv4 on the same on/off switch, maybe?
