  • #6943
    The Ratt Deluxe has 2 switches to vary the clipping.  The PCB shows a number 1 where both of these 2 switches are to be connected.  What does this number 1 refer to?  Which lug of each of the two switches is supposed to be connected to this number 1 connection point on the PCB?
    Thank you, KeneK
    #6944
    The silkscreen diagram for the switch pads is also used for pots.  The number 1 is a guide for using the number 1 lug of the pot to provide correct rotation.
    When installing switches,  the number 1 does not have any particular meaning.  You can install a SPST switch into either pads.Using a SPDT switch, just install the middle lug to the middle pad.  The other lugs can be installed into either remaining pads.
    #6947
    Thank you very much – the friendliest and most helpful site I have ever encountered!
