  • #37654
    Bug
    Hi, I’m new here although I’ve been lurking on other pedal forums for a while.
    I saw that the Build Document for Mastadon Fuzz has a diagram for how to add Buff and Blend to it. But the Ratt build guide doesn’t have this. Is there a reason to not use a Buff and Blend with a Ratt? It doesn’t invert the signal than I can see, so not that.
    Thanks
    #37660
    The Mastodon Fuzz is just an extraordinarily good pairing with the Buff N Blend particularly if you want to use it on Bass. The short answer is that I didn’t create individual Buff N Blend wiring diagrams for every circuit I offer, as that wouldn’t be efficient since the Buff N Blend build document already covers the necessary wiring details. So, you can choose to use it with whatever circuit you wish.
    #37664
    Bug
    Thanks a lot. I’ll put a Buff Mastadon on my wishlist. 🙂
