Good afternoon all,
I just built the Pedal PCB Muffin Fuzz and I’m finishing up the Tone Tweq (just waiting on the vertical trim pot for the vol and a few 9mm pots).
I want to have the Tone Tweq act as an EQ for the Muffin Fuzz. From my understanding I would wire it the same way as outlined in the build docs with the Red Special. I just want to confirm that. I will set the internal volume trimpot on the Tweq to unity gain, so I would have the Vol/Fuzz/Tone on the Muffin Factory and the High/Mid/Low on the Tweq as onboard adjustable pots.
This is my first combo build so I just want to make sure I’m doing it right.
Thank you all as always
