Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › General DIY Pedal Discussion › Purple build
- This topic has 11 replies, 3 voices, and was last updated 2 weeks, 5 days ago by
Mikey.
September 30, 2025 at 1:49 pm #37492
Mikey
Participanton q1 does charge or emitter go to c4
September 30, 2025 at 1:50 pm #37493Mikey
ParticipantPurp build not purple
September 30, 2025 at 7:30 pm #37495
PlaysforfunModeratorGoogle, my friend.
September 30, 2025 at 8:19 pm #37496
BarryKeymasterThe little Tip on the silkscreen is always the Emitter, Base is the center, and Collector is the other side.
October 1, 2025 at 1:26 pm #37500Mikey
ParticipantOk thank you guys. Whole new set of issues now on this build. So I am daisy chaining the tone tweak into the purp I get no signal from the tone tweak but I do get signal from the purp but gives the opposite effect. It cuts instead of bosts I also modded the grit with a A10k potentiometer instead of the trim 10k. The transistor I used is an A92 it read 137 hfe on my mm. Not sure if that is the issue or not but just trying to figure it out I have power to everything and I have tested for continuity to both boards. But that’s as far as I got.
Here’s a pic of the build.
October 2, 2025 at 4:18 pm #37514
PlaysforfunModeratorYou may be going a little too fast, Mickey. Lets start with two working boards before combining them. I don’t see anything wrong but I can’t see much from your photo. You may need to start a build support thread.
October 2, 2025 at 5:55 pm #37520Mikey
ParticipantOk well I will un solder the breakouts and start with the purp
October 2, 2025 at 6:26 pm #37523
BarryKeymasterEarlier I mentioned that the Emitter is always the pad near the Tip (or Tab) on the silkscreen
When I looked up a datasheet for an A92 transistor (see below) it shows that you have the Collector side soldered to the pad with the Tip aka the Emitter. So it would appear that the transistor is in upside down.
October 5, 2025 at 9:16 am #37543Mikey
Participant<hr />
Thank you sir I unsoldered it from the other board to further test but haven’t got much further I will reverse that next and see where that takes me.
October 5, 2025 at 1:11 pm #37548Mikey
ParticipantOk so reversed and changed out the A92 to n3906 and actually the pin out for the 3906 is the same as the A92 so with doing that the purp side is fixed. But started working on the tone tweak board and I have tried to test everything with volts and continuity. Found I didn’t have volt passing through R1 and R12 so lifted one leg to test each couldn’t get a reading so replaced both. I THEN did my bench amp testing and I have through signal but as soon as I hit the switch I get nothing still. I AM at a loss now. Lol thank you for any help.
October 5, 2025 at 7:00 pm #37556
PlaysforfunModeratorOK great. So the PURP is good to go. I would suggest starting a support thread for the Tone TwEQ complete with all the clear photos and voltages that we like and we can help figure it out.
October 5, 2025 at 9:34 pm #37557Mikey
ParticipantI will do that. But right now I have another side project. Going its hunting season here and I process game on the side and had a elk brought to me so it’ll be a few days before I get to it. Thanks for the help so far.
