  • #35511
    Hi, I know this is a stupid question but can someone please tell me how to print the templates in the build pages to the correct scale? In this case it is the Tube Screamer pre Amp. I’m not sure what percentage I’m meant to set my printer to and am tired of the hit and miss approach.
    Thanks in advance to anyone who can help.
    #35518
    It is printing precisely. All PCB Pot lugs match perfectly with printed ones. (see image below).
    The problem is in your print settings.
    Likely there is Print Scaling issue or you have the wrong paper size selected. (easy to do) That would also explain why you are always getting different results.
    Set Print Scaling to 100% (Actual Size)
    • Open the PDF in Adobe Acrobat Reader or your preferred PDF viewer.
    • Press Ctrl + P (or go to File > Print).
    • Look for a scaling option (usually in the print settings). or Advanced Settings
    • Set it to “Actual Size” or “100%” (instead of “Fit to printable area” or “Shrink to Fit”).
    Set Paper Size to Match Your Printer Settings
    • Go to Layout > Size and ensure the paper size matches the one selected in your printer settings (e.g., Letter 8.5″x11″).
    • If there’s a mismatch, the program may be shrinking content to fit the page.
    #35522
    Thank you so much Barry!
    Awesome pedal! Thank you for all your hard work.
