Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › Plexi Plus Biasing issue (solved)
- This topic has 5 replies, 3 voices, and was last updated 6 years, 1 month ago by
Chris.
September 18, 2020 at 12:08 am #14824
ChrisParticipantHi, I have built 2 plexi plus circuits with the tone tweaker board. The second one has a drastically lower output than the first, and when I bias Q1,3&5 to 5v I get almost no volume. In the build document the q1 voltages are all 0. When i bias Q1-D to 0, Q2,3&5 all fall in the correct voltages but Q4 is very low (.4ish). I am wondering if my Q4 could be bad, as I know J201s can be iffy these days. Any ideas?
Can add pictures if needed, but the voltages currently are: Q1:0v, Q2:5v, Q3:9.23v, Q4:.43v Q5:4.73v
Thanks – Chris
September 18, 2020 at 12:30 am #14825
BillyModeratorIt looks to me that Q1, 2 and 5 drain should be set to around 5v
I haven’t built this circuit but it appears it may be a typo looking at the important bias information
I’d post pictures anyway
September 18, 2020 at 12:54 am #14826
ChrisParticipantWhen I set q1 to 5v, I had NO volume until I was “turned to 11”.
I think the problem is in the Norm channel, as isolated it doesn’t seem correct. Q4 is outside the expected values though so I’m still suspicious of that.here are some pictures…it’s in a “pedalboard build”.
September 18, 2020 at 2:14 am #14828
BillyModeratorChris If you haven’t already check the voltages on your working circuit for comparison
I don’t see anything amiss can’t see R2 and 13
Q4 drain should be the same as Q3 source looking at the schematic what do you get on Q3 gate
September 18, 2020 at 7:01 pm #14844Anonymous
GuestSet the voltage for Q1, Q2 and Q5 drains at 5V or as close as you can. The voltage for Q3 should be close to 9V. Q4 drain will be the same as Q3 sourcel Then do an audio test.
The voltages shown on the build doc list are just samples for the format of how the voltages should be reported. The instructions to set the voltages of Q1, Q2 and Q5 to 5V are correct.
October 3, 2020 at 9:08 pm #15061
ChrisParticipantThanks everyone! I was able to reset the biases and get the pedal working, albeit not at the 5v. I think the J201 transistors i got were a little out of spec so I had to bias them a bit cold for the desired tone. @wilkie1 & @billy – thanks for the explanation on the Q3-4 source-drain relationship!
