I don’t think the transistor change is going to make much of a difference. I tried different transistors and found that higher gain transistors of around 400 hfe or greater worked better.
Pink Jimi Photon stated that the diode should not make that much of a difference. Look up the thread on “zener diode question” and you will have a more full explanation.
Author
