Your Source for DIY Pedal PCBs and NostalgiTone! › GuitarPCB Forum › GuitarPCB Build Support › One Knobb Fuzz 3PDT Wiring Double Check Question
  • #20106
    Thanks for checking out my question.
    This is my first build and I know pretty close to nothing when it comes to electronics. I already pooched a 3PDT board and switch and I’m a little nervous now.
    If someone could validate this statement it would help me understand what I am supposed to do:
    <span style=”font-size: 120%;”>I should use the wiring scheme used for mounting the LED on the 3PDT board (the one with the arrow).</span>
    I’m confused because there are two diagrams on the instructions, with the only difference appearing to be that the left diagram has the LED on the main circuit board while the right schematic has the LED on the 3PDT board. I looked around on the forum but I didn’t see anything about it.
    Again, thanks everyone.
    #20107
    You can do it either way. It all depends on the builder preference.
    I prefer the 3PDT wiring board but not everyone uses them.
    #20162
    Thanks Barry!
