  • #24392
    I have purchased the set for the P.U.F.F. about 2 years ago. Only today I started the assembly. However, the plans available are only for the v5_2021.
    Does anyone still have the old layout and parts list? I’d appreciate if you could post it here.
    Many thanks, Axel
    #24393
    #24397
    Many thanks for your speedy reply.  This greatly helps, though my version of the P.U.F.F. is still older or at least different (PCB layout with the IC to the bottom left in horizontal position).  Anyway, I think I figured it out.
    One more question: R3 is defined as 330/470R, with both resistors supplied. Is this a trial-and-error, or is there any recommendation for the value?
    #24398
    Although there is no discussion of this in the Build Document, I believe the 2 resistor values are provided if you have trouble achieving a bias voltage in the preferred range or tone.  You may wish to socket this position and try both values.  The link provided does provide a much greater discussion of this circuit.
    http://www.geofex.com/article_folders/fuzzface/fffram.htm
    #24399
    Thanks, that helps. I have already ordered a socket to solder to the PCB for easy resistor exchange.  I will see how the biasing is working then, I have never done that before…
