  • #32038
    Hi
    I have an old Muff’n PCB and looking through the build docs, I can’t seem to find a version with the same shaped PCB.
    Can I please check which build doc I should be using?
    Thank you
    #32044
    A lot of material was lost a very long time ago in a site crash. V2 was a very limited run.
    That said it is all the same BOM and schematically. Cosmetic component placement changes only.
    Be sure to use the actual T Pad for in and out Audio wiring and not the extra ground pad right beside by mistake. That was the main reason for a change at that time. We highlighted the silk screen for that T Pad. While we were at it we made a few minor cosmetic changes but nothing regarding how to build or populate.
    I was able to find the advanced section online and take 3 screenshots.
    I hope that helps.
    #32054
    That’s great, thank you!
